Philco 89 Detector Coil
That's good news. What is the wire size?
Thank you,
Philco 89 Detector Coil - by radiodale - 09-27-2014, 08:23 PM
RE: Philco 89 Oscillator Coil - by morzh - 09-27-2014, 08:35 PM
RE: Philco 89 Oscillator Coil - by radiodale - 09-27-2014, 09:12 PM
RE: Philco 89 Oscillator Coil - by morzh - 09-27-2014, 09:58 PM
RE: Philco 89 Detector Coil - by radiodale - 09-29-2014, 05:13 PM
RE: Philco 89 Detector Coil - by morzh - 09-29-2014, 08:55 PM
RE: Philco 89 Detector Coil - by radiodale - 09-29-2014, 09:59 PM
RE: Philco 89 Detector Coil - by radiodale - 09-30-2014, 10:01 PM
RE: Philco 89 Detector Coil - by radiodale - 10-02-2014, 09:53 PM
RE: Philco 89 Detector Coil - by mikethedruid - 10-02-2014, 11:08 PM
There are currently 3031 online users. [Complete List]
» 2 Member(s) | 3029 Guest(s)
