  • 1 Vote(s) - 5 Average
16 B X 2 Shadowmeters
OK went out and measured AVC voltage  again and measured at grid of 78 QAVC tube. -1.75 tuned in and - 0.387 off tune so it looks like not enough AVC to move the meter.  Now to figure out what is causing the lack of voltage there .
I didn't mention that I live in a very rural area and get virtually no am stations here so I am talking about my AMT 3000 transmitter as I mention a "strong" station. I do get Quite a few SW stations at various times though so the radio does seem to perform pretty well. As far as the code 125 version, I am getting excellent performance with stations all over the SW dial. But right now I am working on the early code 121 and trying to solve these one at a time.
I also swapped out all of the front end tubes with no change in performance at all just to be thorough.
Frank
16 B X 2 Shadowmeters - by francois8890 - 09-28-2014, 08:10 PM
RE: 16 B X 2 Shadowmeters - by PAradiogeek - 09-29-2014, 10:13 AM
RE: 16 B X 2 Shadowmeters - by francois8890 - 09-29-2014, 01:24 PM
RE: 16 B X 2 Shadowmeters - by Mondial - 09-29-2014, 03:00 PM
RE: 16 B X 2 Shadowmeters - by francois8890 - 09-29-2014, 03:08 PM
RE: 16 B X 2 Shadowmeters - by PAradiogeek - 09-29-2014, 03:08 PM
RE: 16 B X 2 Shadowmeters - by francois8890 - 09-29-2014, 03:14 PM
RE: 16 B X 2 Shadowmeters - by francois8890 - 09-29-2014, 04:31 PM
RE: 16 B X 2 Shadowmeters - by francois8890 - 10-01-2014, 09:03 AM
RE: 16 B X 2 Shadowmeters - by francois8890 - 10-02-2014, 02:59 PM
RE: 16 B X 2 Shadowmeters - by Warren - 10-02-2014, 07:58 PM
RE: 16 B X 2 Shadowmeters - by francois8890 - 10-04-2014, 11:23 PM
There are currently 2158 online users. [Complete List]
» 2 Member(s) | 2156 Guest(s)
