Bakelite restoration
I believe it was someone on this forum that recommended a product called "Scratch Out" Made by Kit.  It can be found at the automotive store and seems to work pretty well for removing minor scratches and producing a decent gloss finish.
Craig R.
Bakelite restoration - by ODPILOT - 09-27-2014, 01:13 PM
RE: Bakelite restoration - by tab10672 - 09-27-2014, 02:35 PM
RE: Bakelite restoration - by Warren - 09-27-2014, 10:09 PM
RE: Bakelite restoration - by Eliot Ness - 09-29-2014, 03:09 PM
RE: Bakelite restoration - by Arran - 09-29-2014, 10:54 PM
RE: Bakelite restoration - by VntgRads - 09-29-2014, 11:50 PM
RE: Bakelite restoration - by ODPILOT - 09-30-2014, 12:25 PM
RE: Bakelite restoration - by EricS - 10-02-2014, 02:02 PM
RE: Bakelite restoration - by ODPILOT - 10-07-2014, 05:26 PM
