Help with proper verbage of a part...
Well the old timers often called an unidentified part a framis. Plural is framae. Indeed the crimp imposed by these little things caused many a cord to fail, but not that many fires. So they used 'em and still do with very few lawsuits.
RE: Help with proper verbage of a part... - by codefox1 - 09-30-2014, 04:12 PM
There are currently 9789 online users. [Complete List]
» 3 Member(s) | 9786 Guest(s)
