38-15 Dial Stringing and 2nd If transformer
 I would likely be impractical to rewind the IF coil, since one from a parts chassis could likely be found, but I would remove the IF coil, melt some of the wax off, and see if there any visible breaks near the ends of the secondary winding?
RE: 38-15 Dial Stringing and 2nd If transformer - by Arran - 09-30-2014, 09:54 PM
There are currently 6414 online users. [Complete List]
» 2 Member(s) | 6412 Guest(s)
