38-2670 cabinet problem
Well fella's, I started to work on the corners today.
Started by sanding down the crack to see what was underneath.
Did not find that the wood under the crack had any signs of cracking.
I will attempt to re-veneer the 2 corner sections.
I have a piece of walnut veneer that should do both corners.
Made a clamping block with the 3/4 inch radius incorpoated into it. Should help keep the new veneer nice and tight while glue sets up.
Wish me luck.
murf
[Image: http://i1161.photobucket.com/albums/q509...eneer1.jpg]
[Image: http://i1161.photobucket.com/albums/q509...eneer2.jpg]
38-2670 cabinet problem - by murf - 09-27-2014, 03:46 PM
RE: 37-675 cabinet problem - by sam - 09-27-2014, 04:25 PM
RE: 37-675 cabinet problem - by OldRestorer - 09-27-2014, 08:51 PM
RE: 37-675 cabinet problem - by OldRestorer - 09-28-2014, 03:07 PM
RE: 37-675 cabinet problem - by murf - 09-28-2014, 04:19 PM
RE: 38-2670 cabinet problem - by Arran - 09-30-2014, 09:47 PM
RE: 38-2670 cabinet problem - by murf - 10-01-2014, 08:02 PM
RE: 38-2670 cabinet problem - by murf - 10-03-2014, 06:18 PM
RE: 38-2670 cabinet problem - by Ron Ramirez - 10-03-2014, 06:37 PM
RE: 38-2670 cabinet problem - by PhilcoJohn - 10-03-2014, 07:25 PM
RE: 38-2670 cabinet problem - by murf - 10-03-2014, 09:31 PM
RE: 38-2670 cabinet problem - by Arran - 10-04-2014, 11:08 PM
RE: 38-2670 cabinet problem - by Eliot Ness - 10-05-2014, 07:52 AM
RE: 38-2670 cabinet problem - by Arran - 10-07-2014, 11:43 PM
RE: 38-2670 cabinet problem - by murf - 10-08-2014, 01:32 PM
RE: 38-2670 cabinet problem - by thirtiesradio - 10-09-2014, 12:38 AM
RE: 38-2670 cabinet problem - by murf - 10-26-2014, 03:01 PM
RE: 38-2670 cabinet problem - by sam - 10-26-2014, 03:29 PM
RE: 38-2670 cabinet problem - by Eliot Ness - 10-26-2014, 03:36 PM
RE: 38-2670 cabinet problem - by klondike98 - 10-26-2014, 03:46 PM
RE: 38-2670 cabinet problem - by thirtiesradio - 10-26-2014, 10:16 PM
RE: 38-2670 cabinet problem - by jerryhawthorne - 10-27-2014, 02:12 PM
There are currently 11253 online users. [Complete List]
» 2 Member(s) | 11251 Guest(s)
