Potentiometer
Your volume pot was replaced at some point in the past. It's in series between the antenna and antenna coil.  You'll just have less ability to lower the volume.
Potentiometer - by Pillo69 - 10-02-2014, 02:11 PM
RE: Potentiometer - by klondike98 - 10-02-2014, 03:14 PM
RE: Potentiometer - by Pillo69 - 10-02-2014, 05:45 PM
There are currently 9955 online users. [Complete List]
» 3 Member(s) | 9952 Guest(s)
