Mikes latest cabinet
I had a problem similar to with with a speaker cabinet build I did a few years ago. I was using Baltic Birch plywood and one of my cuts was off by a very small fraction. I was able to cut a very thin "shim" with my table saw - just a thin strip and drop it down into the gap. A little glue on each side and it was a perfect fit. I would think the same technique might work here. Use a thin piece of wood or veneer and just cut a narrow strip and glue it in place. Make sure it is a bit "thicker" than it needs to be so it can be sanded down so it is level and smooth.
Mikes latest cabinet - by OldRestorer - 10-01-2014, 08:17 AM
RE: Mikes latest cabinet - by morzh - 10-01-2014, 08:28 PM
RE: Mikes latest cabinet - by OldRestorer - 10-02-2014, 12:32 PM
RE: Mikes latest cabinet - by tab10672 - 10-02-2014, 09:05 PM
RE: Mikes latest cabinet - by EricS - 10-03-2014, 08:33 AM
RE: Mikes latest cabinet - by PhilcoJohn - 10-03-2014, 07:27 PM
RE: Mikes latest cabinet - by OldRestorer - 09-15-2015, 02:24 PM
RE: Mikes latest cabinet - by morzh - 09-15-2015, 04:04 PM
RE: Mikes latest cabinet - by OldRestorer - 09-23-2015, 03:51 PM
RE: Mikes latest cabinet - by codefox1 - 09-24-2015, 08:29 PM
RE: Mikes latest cabinet - by OldRestorer - 09-28-2015, 11:37 AM
