I'm not sure if this is a gain or loss.
Contrary to humans, radios can unconditionally be restored, it's just a matter of time and money. It's gonna have to be taken apart completely. If the iron and coils are still good, and you can restore the tuning capacitor, the rest is cake, but probably won't be finished until next spring. Up to you.
RE: I'm not sure if this is a gain or loss. - by codefox1 - 10-04-2014, 01:07 PM
There are currently 6578 online users. [Complete List]
» 2 Member(s) | 6576 Guest(s)
