Model 610 bakelite block
I gutted the bakelite block for condenser C23, and now I'm not sure how the replacement capacitors are supposed to be connected.  This is Part No. 4989-FU, with 0.09 and 0.01 mfd capacitors.  This block does not have an electrical ground connection to the fastener.  Can someone help?
Model 610 bakelite block - by Kestas - 10-04-2014, 07:26 PM
RE: Model 610 bakelite block - by radiohenry - 10-04-2014, 07:37 PM
RE: Model 610 bakelite block - by klondike98 - 10-04-2014, 08:00 PM
RE: Model 610 bakelite block - by Radioroslyn - 10-04-2014, 08:22 PM
RE: Model 610 bakelite block - by Kestas - 10-05-2014, 10:10 AM
RE: Model 610 bakelite block - by Radioroslyn - 10-05-2014, 10:20 AM
RE: Model 610 bakelite block - by Kestas - 10-05-2014, 10:31 AM
RE: Model 610 bakelite block - by Radioroslyn - 10-05-2014, 12:46 PM
There are currently 2081 online users. [Complete List]
» 1 Member(s) | 2080 Guest(s)
