New CL find 38-116
I picked up this 38-116 this morning while visiting in NY.  The cabinet has a very nice originnal finish.  The chassis has only had one e-cap replaced.
[Image: http://i1033.photobucket.com/albums/a414...6346f9.jpg]
[Image: http://i1033.photobucket.com/albums/a414...449efa.jpg]
[Image: http://i1033.photobucket.com/albums/a414...285930.jpg]
New CL find 38-116 - by SteveJB - 10-04-2014, 08:53 PM
RE: New CL find 38-116 - by PhilcoJohn - 10-04-2014, 10:00 PM
RE: New CL find 38-116 - by thirtiesradio - 10-05-2014, 12:51 AM
RE: New CL find 38-116 - by SteveJB - 10-05-2014, 08:12 AM
There are currently 9490 online users. [Complete List]
» 1 Member(s) | 9489 Guest(s)
