Model 610 bakelite block
Thanks, Terry. This is a table model. Waiting in the queue are three consoles --- 37-620, 90, 91, and a tabletop 20. I'm hooked. 35 years ago I restored a fully working 42-1013, that now needs a full electronic restoration.
Model 610 bakelite block - by Kestas - 10-04-2014, 07:26 PM
RE: Model 610 bakelite block - by radiohenry - 10-04-2014, 07:37 PM
RE: Model 610 bakelite block - by klondike98 - 10-04-2014, 08:00 PM
RE: Model 610 bakelite block - by Radioroslyn - 10-04-2014, 08:22 PM
RE: Model 610 bakelite block - by Kestas - 10-05-2014, 10:10 AM
RE: Model 610 bakelite block - by Radioroslyn - 10-05-2014, 10:20 AM
RE: Model 610 bakelite block - by Kestas - 10-05-2014, 10:31 AM
RE: Model 610 bakelite block - by Radioroslyn - 10-05-2014, 12:46 PM
There are currently 8829 online users. [Complete List]
» 1 Member(s) | 8828 Guest(s)
