Philco 80 different components
In the diagram 80 Philco pin 4 of the second valve 36 is grounded.
In my Philco is connected to ground, so it also has a resistor and capacitor to the central terminal of the oscillator coil.
I've seen some pictures where also other devices have that connection.
The connection of the resistor and capacitor is correct ?. A which is due ?.
Thank you.
[Image: http://s3.postimg.org/jkheaeg5f/106_1.jpg]
subirimagenes
Philco 80 different components - by Pillo69 - 10-05-2014, 11:14 AM
RE: Philco 80 different components - by Pillo69 - 10-05-2014, 08:00 PM
RE: Philco 80 different components - by Pillo69 - 10-07-2014, 07:25 PM
