Newbie
Welcome, Pat! Great photo. I believe that's a 1940 model 40-180 Philco, however. The 1939 model 39-31 had an all white dial face. I have a model 40-180. They're a great sounding set.
Newbie - by Patrick - 10-05-2014, 10:29 AM
RE: Newbie - by sam - 10-05-2014, 12:22 PM
RE: Newbie - by Paul Philco322 - 10-05-2014, 12:53 PM
RE: Newbie - by Patrick - 10-05-2014, 01:14 PM
RE: Newbie - by Radioroslyn - 10-05-2014, 01:46 PM
RE: Newbie - by Patrick - 10-05-2014, 02:33 PM
RE: Newbie - by NostalgiaRadioTime - 10-05-2014, 02:00 PM
RE: Newbie - by Patrick - 10-05-2014, 02:38 PM
RE: Newbie - by Art Hoch - 10-07-2014, 11:55 AM
RE: Newbie - by PhilcoJohn - 10-07-2014, 06:32 PM
RE: Newbie - by Patrick - 10-07-2014, 07:32 PM
RE: Newbie - by klondike98 - 10-08-2014, 06:19 PM
There are currently 2068 online users. [Complete List]
» 1 Member(s) | 2067 Guest(s)
