49-905 IF Transformer disassembly question
There is usually also a set of bent inward indentations or tabs of aluminum from the side of the can that help secure the can to the internal coil assembly. These can be straightened and flattened out to allow the internal parts to be removed gently. Be careful as the internal plastic has become brittle with age. If in doubt, post pictures here and ask questions.
Joe
RE: 49-905 IF Transformer disassembly question - by Joeztech - 10-05-2014, 02:01 PM
