Alignment question
Not sure I know how to check the coils for continuity.  However, I messed with it after I wrote the above post.  I thought that the coaxial cable that is screwed into the "RF Out" of the signal generator would act like an antenna.  It does not.
When I bring the entire signal generator next to the antenna in the Philco radio,  I then hear the signal MUCH louder.  Maybe I'll try it again with the 455 KHz method and see if that works better now that I know the RF signal comes out of the actual signal generator unit better than the coaxial cable I was trying to use like an antenna.
Alignment question - by ODPILOT - 10-05-2014, 08:23 PM
RE: Alignment question - by morzh - 10-05-2014, 08:45 PM
RE: Alignment question - by ODPILOT - 10-05-2014, 10:15 PM
RE: Alignment question - by Warren - 10-06-2014, 12:40 AM
RE: Alignment question - by Mondial - 10-06-2014, 10:28 AM
RE: Alignment question - by ODPILOT - 10-06-2014, 01:02 PM
RE: Alignment question - by codefox1 - 10-06-2014, 02:45 PM
RE: Alignment question - by Warren - 10-06-2014, 02:58 PM
