Alignment question
WARREN -  The signal generator I have has a coaxial cable connected to the RF out and the cable has an alligator clip on the end.  If I make my own antenna,  I hook both ends of the wires to the alligator clip  OR one end to the alligator clip, and the other to what ?
MONDIAL -  If I "inject" the signal from the generator directly into the antenna section of the radio with a capactor in the line,  will that do it - or is there a ground and/or another part of the signal generator that needs to be attached to a ground in the radio as well?
Thanks
Alignment question - by ODPILOT - 10-05-2014, 08:23 PM
RE: Alignment question - by morzh - 10-05-2014, 08:45 PM
RE: Alignment question - by ODPILOT - 10-05-2014, 10:15 PM
RE: Alignment question - by Warren - 10-06-2014, 12:40 AM
RE: Alignment question - by Mondial - 10-06-2014, 10:28 AM
RE: Alignment question - by ODPILOT - 10-06-2014, 01:02 PM
RE: Alignment question - by codefox1 - 10-06-2014, 02:45 PM
RE: Alignment question - by Warren - 10-06-2014, 02:58 PM
