Alignment question
I connected one end of the home made ant to the ground from the sg and the other end to the output of the sg. Then I got a signal.
Alignment question - by ODPILOT - 10-05-2014, 08:23 PM
RE: Alignment question - by morzh - 10-05-2014, 08:45 PM
RE: Alignment question - by ODPILOT - 10-05-2014, 10:15 PM
RE: Alignment question - by Warren - 10-06-2014, 12:40 AM
RE: Alignment question - by Mondial - 10-06-2014, 10:28 AM
RE: Alignment question - by ODPILOT - 10-06-2014, 01:02 PM
RE: Alignment question - by codefox1 - 10-06-2014, 02:45 PM
RE: Alignment question - by Warren - 10-06-2014, 02:58 PM
There are currently 4947 online users. [Complete List]
» 3 Member(s) | 4944 Guest(s)
