Model 37-84 low volume on lower frequencies
Everything done, caps and resistors, alignment....but strangely I get good volume on 1320 on the dial....but low volume on KDKA ....the big station in Pittsburgh and at 1020 on the dial.  The selectivity knob seems to do nothing...nor the antenna and osc. trimmers on the tuning cap.  Any thoughts????
Model 37-84 low volume on lower frequencies - by sjhs1962 - 10-06-2014, 05:48 PM
