low volume on Philco model 20
Have you replaced the capacitors on this set? Even if it is not humming, I'll bet an open capacitor is just begging to be coupled to the B- or ground. Of course it could be that the volume control needs a good shot of De-Oxit oe othr cleaner to clear it out. Start from here, and let us know what you find.
low volume on Philco model 20 - by phil vanderoef - 12-21-2008, 07:17 PM
Re: low volume on Philco model 20 - by codefox1 - 12-21-2008, 08:27 PM
There are currently 8542 online users. [Complete List]
» 1 Member(s) | 8541 Guest(s)
