Capacitor ID help
What meter do you have?
before you discard anything, measure your leads' capacitance; it very well might be you are measuring them plus your cap.
Capacitor ID help - by ODPILOT - 10-07-2014, 09:02 AM
RE: Capacitor ID help - by morzh - 10-07-2014, 10:02 AM
RE: Capacitor ID help - by Steve Davis - 10-07-2014, 11:29 AM
RE: Capacitor ID help - by morzh - 10-07-2014, 11:54 AM
RE: Capacitor ID help - by ODPILOT - 10-07-2014, 05:14 PM
RE: Capacitor ID help - by morzh - 10-07-2014, 05:30 PM
RE: Capacitor ID help - by ODPILOT - 10-08-2014, 05:52 PM
RE: Capacitor ID help - by Joeztech - 10-08-2014, 08:23 PM
There are currently 9672 online users. [Complete List]
» 1 Member(s) | 9671 Guest(s)
