16B cathedral cabinet face and arch
Thanks for the help.  I have all the screws out, but the face seems like it is glued in tight. Ill keep trying.
I thought of making a new wrap around but it may be over my skill level.  Only the top layer is coming off.  Maybe I could glue a new walnut veneer in place of that.
16B cathedral cabinet face and arch - by SteveJB - 10-07-2014, 09:19 AM
RE: 16B cathedral cabinet face and arch - by SteveJB - 10-07-2014, 09:09 PM
There are currently 10328 online users. [Complete List]
» 2 Member(s) | 10326 Guest(s)
