Questions about Philco TV/radio cabinet and speakers
Take a look around inside the cabinet and see if you can find a tag with the model number on it. if it is old than 1954 the first two digits of the model number is the year of manufacture. 1954 and later it will start with a letter Tell the letter and I can tell you the year in was made.
Welcome!!!
Questions about Philco TV/radio cabinet and speakers - by HistoricDistrictFurnishings - 10-08-2014, 10:05 AM
RE: Questions about Philco TV/radio cabinet and speakers - by Radioroslyn - 10-08-2014, 06:12 PM
There are currently 2139 online users. [Complete List]
» 2 Member(s) | 2137 Guest(s)
