Also a newbie
Bill
Even if the radio is restored, be carefull operating it, Transitones are mostly AC/DC sets without transformers and present some hazard when used near grounded objects or in basements.
GFI outlet helps.
Mike
PS. If it has not been restored, do not attempt plugging it in.
Also a newbie - by bsteach@sbcglobal.net - 10-08-2014, 02:27 PM
RE: Also a newbie - by Ron Ramirez - 10-08-2014, 04:13 PM
RE: Also a newbie - by klondike98 - 10-08-2014, 06:13 PM
RE: Also a newbie - by morzh - 10-08-2014, 08:09 PM
RE: Also a newbie - by exray - 10-08-2014, 09:04 PM
RE: Also a newbie - by PhilcoJohn - 10-09-2014, 06:25 PM
RE: Also a newbie - by KCMike - 10-09-2014, 08:38 PM
RE: Also a newbie - by gregb - 10-09-2014, 11:20 PM
RE: Also a newbie - by bsteach@sbcglobal.net - 10-10-2014, 11:11 AM
RE: Also a newbie - by bsteach@sbcglobal.net - 10-10-2014, 11:40 AM
There are currently 7791 online users. [Complete List]
» 1 Member(s) | 7790 Guest(s)
