Philco 38-116X vs RCA 15K
First of, check your parts before taking them out. Otherwise you will be doing lots of work you could've avoided.
What else....there are nothibf else in the socket usually, just wires.
Have you made sure the tube's good?
Does your AVC work?
Philco 38-116X vs RCA 15K - by Jayce - 03-13-2013, 04:19 PM
RE: Philco 38-116X vs RCA 15K - by y2kbruce - 03-13-2013, 04:47 PM
RE: Philco 38-116X vs RCA 15K - by Jayce - 03-13-2013, 05:04 PM
RE: Philco 38-116X vs RCA 15K - by Arran - 03-13-2013, 07:37 PM
RE: Philco 38-116X vs RCA 15K - by Jayce - 03-13-2013, 10:55 PM
RE: Philco 38-116X vs RCA 15K - by morzh - 03-13-2013, 11:36 PM
RE: Philco 38-116X vs RCA 15K - by OldJack1969 - 10-10-2014, 07:04 PM
RE: Philco 38-116X vs RCA 15K - by jontz - 03-14-2013, 07:14 AM
RE: Philco 38-116X vs RCA 15K - by morzh - 03-14-2013, 06:08 PM
RE: Philco 38-116X vs RCA 15K - by jontz - 03-14-2013, 09:28 PM
RE: Philco 38-116X vs RCA 15K - by Arran - 03-14-2013, 09:41 PM
RE: Philco 38-116X vs RCA 15K - by morzh - 03-14-2013, 09:51 PM
RE: Philco 38-116X vs RCA 15K - by Jayce - 03-14-2013, 10:58 PM
RE: Philco 38-116X vs RCA 15K - by morzh - 03-15-2013, 10:20 AM
RE: Philco 38-116X vs RCA 15K - by TA Forbes - 03-15-2013, 07:24 PM
RE: Philco 38-116X vs RCA 15K - by morzh - 10-10-2014, 09:27 PM
RE: Philco 38-116X vs RCA 15K - by thirtiesradio - 12-12-2014, 04:49 PM
RE: Philco 38-116X vs RCA 15K - by Arran - 12-13-2014, 02:10 AM
RE: Philco 38-116X vs RCA 15K - by Phlogiston - 12-13-2014, 09:07 PM
RE: Philco 38-116X vs RCA 15K - by thirtiesradio - 12-14-2014, 02:26 AM
RCA T62 is playing.....
Philco 91 Restore Code ??
Philco 40-120C Restoration
Philco 89 indicator light.
