Starting 37-116 Deluxe Restoration
Drill little holes in the insulator adjacent to each terminal and pass each wire up through and solder to the respective lug. The rivets themselves are made of aluminum, so solder does not stick.
Starting 37-116 Deluxe Restoration - by Nick3092 - 08-28-2014, 11:49 AM
RE: Starting 37-116 Deluxe Restoration - by morzh - 08-28-2014, 01:46 PM
RE: Starting 37-116 Deluxe Restoration - by morzh - 08-28-2014, 02:43 PM
RE: Starting 37-116 Deluxe Restoration - by morzh - 08-28-2014, 05:53 PM
RE: Starting 37-116 Deluxe Restoration - by Mondial - 10-11-2014, 09:19 AM
RE: Starting 37-116 Deluxe Restoration - by morzh - 10-11-2014, 07:40 PM
RE: Starting 37-116 Deluxe Restoration - by morzh - 10-12-2014, 09:22 PM
RE: Starting 37-116 Deluxe Restoration - by morzh - 10-14-2014, 07:31 PM
RE: Starting 37-116 Deluxe Restoration - by morzh - 10-17-2014, 03:56 PM
RE: Starting 37-116 Deluxe Restoration - by morzh - 10-18-2014, 02:05 PM
RE: Starting 37-116 Deluxe Restoration - by morzh - 10-18-2014, 07:18 PM
RE: Starting 37-116 Deluxe Restoration - by morzh - 10-18-2014, 07:36 PM
RE: Starting 37-116 Deluxe Restoration - by morzh - 10-18-2014, 10:16 PM
RE: Starting 37-116 Deluxe Restoration - by morzh - 10-19-2014, 07:38 PM
RE: Starting 37-116 Deluxe Restoration - by morzh - 10-29-2014, 09:12 PM
RE: Starting 37-116 Deluxe Restoration - by gvel - 11-02-2014, 06:52 PM
Eico 232 VTVM Schematic
