41-81T my next project
My next Philco project is going to be a 41-81T, portable, battery powered radio. I picked it up very reasonably on ePay, which was a pleasant surprise. I was expecting to be outbid. When I received it and opened it, I found that the original Philco battery was still inside ! Even more amazing is that the battery has not leaked, and so I have one with good outside graphics, which I have scanned, so I can make a cover for the replacement battery unit I will make for it. Here are some pictures of it on my work bench.
[Image: https://33.media.tumblr.com/c5503dc8bd4f...1_1280.jpg]
[Image: https://33.media.tumblr.com/0750bac62203...1_1280.jpg]
[Image: https://33.media.tumblr.com/da165c1935b1...2_1280.jpg]
Should keep me amused for some weeks. Icon_e_biggrin
41-81T my next project - by mikethedruid - 10-11-2014, 03:27 PM
RE: 41-81T my next project - by klondike98 - 10-11-2014, 09:21 PM
RE: 41-81T my next project - by Ron Ramirez - 10-11-2014, 09:46 PM
RE: 41-81T my next project - by mikethedruid - 10-11-2014, 11:36 PM
RE: 41-81T my next project - by morzh - 10-12-2014, 02:47 PM
RE: 41-81T my next project - by mikethedruid - 12-18-2014, 03:18 AM
There are currently 9786 online users. [Complete List]
» 3 Member(s) | 9783 Guest(s)
