Philco 40-180 Dial Cord Routing
Wow does this thing look a bit bizarre - tuning wheel 90degrees perpendicular to the route of the pulleys on the dial face. The path from the tuning knob, dial face are all parallel, but the tuning cap wheel is perpendicular to this path - documentation from Nostalgia Air almost seem as if all wheels and pulleys are parallel with each other. Any further documentation or assist would be greatly appreciated.
Philco 40-180 Dial Cord Routing - by mgambuzza - 10-11-2014, 04:52 PM
There are currently 8762 online users. [Complete List]
» 2 Member(s) | 8760 Guest(s)
