I need help identifying my philco
Sets built between 1937 and 1953 have model numbers that start withe the last two digits of the year of manufacture. After 1953 the model starts with a letter. See Ron's info here http://www.philcoradio.com/age.htm
I need help identifying my philco - by carrington093 - 10-12-2014, 12:52 PM
RE: I need help identifying my philco - by sam - 10-12-2014, 01:09 PM
RE: I need help identifying my philco - by morzh - 10-12-2014, 02:41 PM
RE: I need help identifying my philco - by klondike98 - 10-12-2014, 07:20 PM
There are currently 9773 online users. [Complete List]
» 3 Member(s) | 9770 Guest(s)
