Speaker woes
Greg, I have minimize something like that by placing the speaker face down and misting water on the cone a little at a time from the back. Once the cone is saturated it is more pliant and you may be able to gently coax it back in shape. Just something I did out of desperation and it worked. Hard to tell from the picture but it appears your surround is well attached?
Jerry
Speaker woes - by NostalgiaRadioTime - 10-13-2014, 05:21 PM
RE: Speaker woes - by jerryhawthorne - 10-13-2014, 07:01 PM
RE: Speaker woes - by NostalgiaRadioTime - 10-13-2014, 09:24 PM
RE: Speaker woes - by morzh - 10-13-2014, 10:13 PM
RE: Speaker woes - by Arran - 10-13-2014, 10:25 PM
RE: Speaker woes - by jerryhawthorne - 10-14-2014, 12:08 AM
RE: Speaker woes - by NostalgiaRadioTime - 10-14-2014, 12:26 AM
RE: Speaker woes - by BrendaAnnD - 10-14-2014, 04:52 AM
RE: Speaker woes - by NostalgiaRadioTime - 10-14-2014, 07:11 AM
There are currently 2705 online users. [Complete List]
» 1 Member(s) | 2704 Guest(s)
