Just bought 37-620 want to get it working
Doc, if you wish to safely install an outside "long wire" antenna, really the best for general short wave listening, you will need insulators and a lightning arrestor, as well as a ground stake and insulators for the lead in wires to the lightning arrestor.
https://33.media.tumblr.com/45174faaa39f...1_1280.jpg
I have drawn a diagram of proper longwire installation. The pulley and weight are optional, they provide relief for the wire in high winds.
RE: Just bought 37-620 want to get it working - by mikethedruid - 10-14-2014, 02:51 PM
There are currently 8737 online users. [Complete List]
» 1 Member(s) | 8736 Guest(s)
