New guy with a PT-6 to Restore
Welcome to the phorum cewrightiii
Nice looking radio
Sam
New guy with a PT-6 to Restore - by cewrightiii - 10-14-2014, 04:38 PM
RE: New guy with a PT-6 to Restore - by sam - 10-14-2014, 07:04 PM
RE: New guy with a PT-6 to Restore - by Arran - 10-16-2014, 12:02 AM
RE: New guy with a PT-6 to Restore - by Arran - 10-16-2014, 11:49 PM
