Philco 71 with an eye tube?
It's not that hard to make a new front panel. I've made a couple of them.
M R Radios   C M Tubes
Philco 71 with an eye tube? - by TonyJSenior - 11-03-2008, 11:09 AM
Re: Philco 71 with an eye tube? - by exray - 11-03-2008, 12:35 PM
Re: Philco 71 with an eye tube? - by AI2V - 11-03-2008, 12:43 PM
Re: Philco 71 with an eye tube? - by Doug Houston - 11-05-2008, 01:02 AM
Re: Philco 71 with an eye tube? - by Steve Davis - 11-05-2008, 09:23 AM
Re: Philco 71 with an eye tube? - by Steve Davis - 11-09-2008, 12:30 AM
There are currently 8452 online users. [Complete List]
» 1 Member(s) | 8451 Guest(s)
