Rebuilding a Philco Tropic 42-730EZ
Here's tonight's progress report:
[Image: http://www.philcoradio.com/images/phorum...e00008.jpg]
Most of the wires have now been replaced. Of all the paper caps you see in the photo above, all are new (restuffed) save one. I have removed the electrolytic cans so they, too, may be restuffed.
Only a few resistors remain to be replaced.
The other original 0.2 uF paper cap's sleeve was too small to accommodate a new 0.22 uF film cap. So I looked around, and found an old Philco 0.25 uF paper cap which was much larger. This is what I used for the second 0.22 uF cap. You can see it in the photo above - it is the largest paper cap under the chassis.
RE: Rebuilding a Philco Tropic 42-730EZ - by Ron Ramirez - 10-14-2014, 09:24 PM
RE: Rebuilding a Philco Tropic 42-730EZ - by sam - 10-15-2014, 04:52 AM
RE: Rebuilding a Philco Tropic 42-730EZ - by sam - 10-19-2014, 05:20 PM
Users browsing this thread: 25 Guest(s)
Restoring Philco 96
There are currently 7788 online users. [Complete List]
» 2 Member(s) | 7786 Guest(s)
