Farm radios....
 Lead acid batteries have been on the market for more then 100 years, more then likely the glass jar 2 volt cells used in a Delco lighting system's battery bank was composed of those. With regard to 32 volt sets I have only seen one example in the past 25 years, and it was a post war Sparton Bakelite set with the 150 ma AC/DC style tubes in a series parallel arrangement, by far most of the DC operated sets manufactured and sold in Canada were of the typical "A", "B", and sometimes "C" powered types, and occasionally the 6 volt vibrator types.
 Unlike some U.S manufacturers the Canadian made 6 volt sets never came with a dual power option where you could switch from 6 volt operation to 117 volt AC operation, in fact most I've seen used battery style tubes in series, which was very efficient.
Farm radios.... - by Farm Radio - 10-06-2014, 10:40 PM
RE: Farm radios.... - by sam - 10-07-2014, 03:31 AM
RE: Farm radios.... - by Farm Radio - 10-08-2014, 12:12 AM
RE: Farm radios.... - by Ron Ramirez - 10-08-2014, 07:44 AM
RE: Farm radios.... - by Eliot Ness - 10-08-2014, 08:36 AM
RE: Farm radios.... - by Chris Cusick - 10-08-2014, 04:01 PM
RE: Farm radios.... - by klondike98 - 10-08-2014, 07:55 PM
RE: Farm radios.... - by Farm Radio - 10-12-2014, 11:23 PM
RE: Farm radios.... - by Arran - 10-13-2014, 12:53 AM
RE: Farm radios.... - by palegreenthumb - 10-13-2014, 02:14 AM
RE: Farm radios.... - by Ron Ramirez - 10-13-2014, 07:32 AM
RE: Farm radios.... - by Farm Radio - 10-13-2014, 04:26 PM
RE: Farm radios.... - by Arran - 10-14-2014, 12:17 AM
RE: Farm radios.... - by cewrightiii - 10-14-2014, 08:31 PM
RE: Farm radios.... - by klondike98 - 10-14-2014, 09:43 PM
RE: Farm radios.... - by Phlogiston - 10-14-2014, 11:31 PM
RE: Farm radios.... - by cewrightiii - 10-15-2014, 09:05 AM
RE: Farm radios.... - by standardtwin - 10-16-2014, 04:26 PM
RE: Farm radios.... - by cewrightiii - 10-16-2014, 04:37 PM
RE: Farm radios.... - by morzh - 10-16-2014, 05:04 PM
RE: Farm radios.... - by Phlogiston - 10-16-2014, 06:01 PM
RE: Farm radios.... - by Warren - 10-16-2014, 06:37 PM
RE: Farm radios.... - by Arran - 10-16-2014, 09:30 PM
RE: Farm radios.... - by standardtwin - 10-17-2014, 09:58 AM
RE: Farm radios.... - by DanH6464 - 11-08-2014, 01:58 PM
RE: Farm radios.... - by Phlogiston - 11-08-2014, 04:13 PM
RE: Farm radios.... - by thirtiesradio - 11-15-2014, 02:15 AM
RE: Farm radios.... - by thirtiesradio - 11-15-2014, 02:26 AM
RE: Farm radios.... - by Paul Philco322 - 11-15-2014, 04:43 PM
RE: Farm radios.... - by thirtiesradio - 11-15-2014, 09:06 PM
There are currently 3484 online users. [Complete List]
» 2 Member(s) | 3482 Guest(s)
