New guy with a PT-6 to Restore
Yes, lacquer/toner is what they used at the factory.
New guy with a PT-6 to Restore - by cewrightiii - 10-14-2014, 04:38 PM
RE: New guy with a PT-6 to Restore - by sam - 10-14-2014, 07:04 PM
RE: New guy with a PT-6 to Restore - by Arran - 10-16-2014, 12:02 AM
RE: New guy with a PT-6 to Restore - by Arran - 10-16-2014, 11:49 PM
RE: New guy with a PT-6 to Restore - by Eliot Ness - 10-17-2014, 04:42 PM
