38-2 tuning mech
Thanks Morzh,
The dial is exactly the same as a 116 I have that console also.This was my thinking,I can take the round area that holds the station tabs and only rotate it a small amount before the band switch starts to engage,as soon is the switch gets to its final position either left or right the mech stops. I removed the plate on the face of the area of the station tabs there
are a ton of adjustment screws these must be station settings,any surprises when i remove this plate.Also one more ?
if I may, the box on the underside of the chassis that houses more components resistors and such there are 4 nuts
2 on either side of the tuning cap do those undo that box.The band switch rod is in there to.
Thanks
38-2 tuning mech - by doug-5er - 10-18-2014, 02:11 PM
RE: 38-2 tuning mech - by sam - 10-18-2014, 02:31 PM
RE: 38-2 tuning mech - by morzh - 10-18-2014, 05:15 PM
RE: 38-2 tuning mech - by doug-5er - 10-18-2014, 06:13 PM
RE: 38-2 tuning mech - by morzh - 10-18-2014, 07:10 PM
RE: 38-2 tuning mech - by doug-5er - 10-18-2014, 08:09 PM
RE: 38-2 tuning mech - by morzh - 10-18-2014, 10:23 PM
RE: 38-2 tuning mech - by doug-5er - 10-18-2014, 10:29 PM
RE: 38-2 tuning mech - by Ron Ramirez - 10-19-2014, 08:29 AM
RE: 38-2 tuning mech - by doug-5er - 10-20-2014, 09:11 AM
RE: 38-2 tuning mech - by morzh - 10-20-2014, 09:32 AM
RE: 38-2 tuning mech - by doug-5er - 10-20-2014, 11:16 AM
RE: 38-2 tuning mech - by morzh - 10-20-2014, 12:14 PM
RE: 38-2 tuning mech - by doug-5er - 10-20-2014, 05:23 PM
RE: 38-2 tuning mech - by morzh - 10-20-2014, 07:24 PM
RE: 38-2 tuning mech - by doug-5er - 10-22-2014, 03:36 PM
RE: 38-2 tuning mech - by doug-5er - 01-31-2015, 11:45 PM
