Model 116 feq range
As Ed stated, it's a hot band at night, especially late at night. The winter months are the best with the lower noise. The lower portion is full of European & African broadcast stations. I can usually pick up Med-1 Morocco late at night very strong. Along with a few others. This is on any one of my Philco's with LW, using a 150' long wire antenna. DXing the NDB(aviation beacons) is a big past time. If you watch the NDB cluster, they are reports for beacons well over 1K miles at night. BTW, I suggest you install a good ground system for noise. This band needs all the help it can get with these old sets since they lack any serious noise filters.
LW/NDB cluster
http://dxworld.com/ndblog.html
BCB cluster
http://dxworld.com/bcblog.html
-Brian
If you collect or are interested in antique telephones, please visit Classic Rotary Phones
http://www.classicrotaryphones.com/forum/index.php
Model 116 feq range - by Dave Slusarczyk - 12-08-2008, 01:16 AM
Re: Model 116 feq range - by rghines1 - 12-08-2008, 09:07 AM
Re: Model 116 feq range - by etech - 12-08-2008, 10:34 AM
Re: Model 116 freq range - by BDM - 12-09-2008, 12:07 AM
There are currently 8875 online users. [Complete List]
» 2 Member(s) | 8873 Guest(s)
