Rebuilding a Philco Tropic 42-730EZ
#50
(10-17-2014, 11:45 PM)Arran Wrote:  In any even it looks like the metal backing plate needs to be taken out, derusted and painted, (or is it rusty brown flocking?)
Forgot to mention: Yes, Arran, that is flocking that has a rusty brown color. I carefully cleaned the glass before reinstalling everything in the cabinet; the photo just above shows the clean glass and you can see the dark brown color of the flocking on the backing plate.
RE: Rebuilding a Philco Tropic 42-730EZ - by sam - 10-15-2014, 04:52 AM
RE: Rebuilding a Philco Tropic 42-730EZ - by Ron Ramirez - 10-18-2014, 10:37 PM
RE: Rebuilding a Philco Tropic 42-730EZ - by sam - 10-19-2014, 05:20 PM
Users browsing this thread: 24 Guest(s)
Restoring Philco 96
There are currently 7755 online users. [Complete List]
» 2 Member(s) | 7753 Guest(s)
