49-905 IF Transformer disassembly question
Morzh
Yes so far I have only looked at one of them for the AM section. I was worried about the silver mica caps inside but stopped short of taking them apart.
Out of the circuit it seems to tune OK. So after reassembly I have tried to align the AM section only. It does align but still sounds bad.
I am not sure if I should put the part about the bad audio/hum and the 35C5 tube in a new thread, I think it's lost here because of the title.
Chris
RE: 49-905 IF Transformer disassembly question - by OZ4 - 10-19-2014, 01:15 PM
