Starting 37-116 Deluxe Restoration
#53
Actually, I lied about the alignment. I missed the part in the dial calibration where you align to the index mark, then turn both the dial and tuner to to like 530, then move just the dial back to the index mark. After doing that, on BC its off by maybe 5kHz. The 5MHz time signal is coming in at like 5.02, the 10 is coming in at like 10.1, and the 15 is coming in at like 15.2. I think I'll just leave it. This thing does not look fun to align. Maybe even just tweak the dial to get rid of that 5kHz difference on BC, as that is mainly what I care about.
Starting 37-116 Deluxe Restoration - by Nick3092 - 08-28-2014, 11:49 AM
RE: Starting 37-116 Deluxe Restoration - by morzh - 08-28-2014, 01:46 PM
RE: Starting 37-116 Deluxe Restoration - by morzh - 08-28-2014, 02:43 PM
RE: Starting 37-116 Deluxe Restoration - by morzh - 08-28-2014, 05:53 PM
RE: Starting 37-116 Deluxe Restoration - by morzh - 10-11-2014, 07:40 PM
RE: Starting 37-116 Deluxe Restoration - by morzh - 10-12-2014, 09:22 PM
RE: Starting 37-116 Deluxe Restoration - by morzh - 10-14-2014, 07:31 PM
RE: Starting 37-116 Deluxe Restoration - by morzh - 10-17-2014, 03:56 PM
RE: Starting 37-116 Deluxe Restoration - by morzh - 10-18-2014, 02:05 PM
RE: Starting 37-116 Deluxe Restoration - by morzh - 10-18-2014, 07:18 PM
RE: Starting 37-116 Deluxe Restoration - by morzh - 10-18-2014, 07:36 PM
RE: Starting 37-116 Deluxe Restoration - by morzh - 10-18-2014, 10:16 PM
RE: Starting 37-116 Deluxe Restoration - by morzh - 10-19-2014, 07:38 PM
RE: Starting 37-116 Deluxe Restoration - by Nick3092 - 10-19-2014, 07:38 PM
RE: Starting 37-116 Deluxe Restoration - by morzh - 10-29-2014, 09:12 PM
RE: Starting 37-116 Deluxe Restoration - by gvel - 11-02-2014, 06:52 PM
