my 41-81T starting with the battery....
Morzh, your a kill joy! You just don't run the radio 24/7. Should last a long time. The joy is that it really looks original and a nice job of it. Personally on the farm radios I have done I built an A/C powersupply into the battery box but nothing looks less original than a "battery" with an A/C cord coming out of it.
Jerry
There are currently 10512 online users. [Complete List]
» 3 Member(s) | 10509 Guest(s)
