46-1201 - Cap question...
Hi all,  long time no post...
I'm working on a 46-1201 radio phono combination and came across an odd capacitor that
I've never seen before.
Keeping in mind that I'm relatively new to all of this,  I've attached the section if the schematic for
this part.  It appears to be a paper capacitor with a coil wrapped around it.
What is it called?  What does it do?  Can I just replace the capacitor and leave the coil alone (it won't
really be wrapped around the capacitor any more)?
Should I just leave the whole thing alone?
Thanks.
46-1201 - Cap question... - by Mr Grumpy - 10-20-2014, 09:13 PM
RE: 46-1201 - Cap question... - by Mondial - 10-20-2014, 09:35 PM
RE: 46-1201 - Cap question... - by Mr Grumpy - 10-21-2014, 11:52 PM
RE: 46-1201 - Cap question... - by PhilcoJohn - 10-27-2014, 06:52 PM
RE: 46-1201 - Cap question... - by Mr Grumpy - 11-03-2014, 04:37 PM
There are currently 3856 online users. [Complete List]
» 1 Member(s) | 3855 Guest(s)
