  • 1 Vote(s) - 5 Average
84B Restoration - update-Touchdown!
Bob
I do not see it here...looks to me like you left all resistors in place and, unless the graphics looks unclear, the caps are also untouched, no?
I know for a fact those big brown resistors are always off, and so are others. Unless you made the new ones.
RE: 84B Restoration - need advice - by klondike98 - 10-09-2014, 02:30 PM
RE: 84B Restoration - need advice - by morzh - 10-09-2014, 03:11 PM
RE: 84B Restoration - need advice - by klondike98 - 10-11-2014, 12:00 PM
RE: 84B Restoration - need advice - by klondike98 - 10-13-2014, 09:57 PM
RE: 84B Restoration - need advice - by morzh - 10-13-2014, 10:10 PM
RE: 84B Restoration - need advice - by klondike98 - 10-13-2014, 10:45 PM
RE: 84B Restoration - need advice - by klondike98 - 10-21-2014, 04:43 PM
RE: 84B Restoration - update-Touchdown! - by morzh - 10-21-2014, 07:09 PM
There are currently 9383 online users. [Complete List]
» 2 Member(s) | 9381 Guest(s)
