WHY IS THIS HAPPENING TO ME!?
Must be just bad luck on your part? Really a great price and the exterior looks great. The bezel appears to be that famous plastic and might have a piece on the corner missing. Not certain if there are repos for this model available. Nice find.
Jerry
WHY IS THIS HAPPENING TO ME!? - by Edisla - 10-22-2014, 12:37 AM
RE: WHY IS THIS HAPPENING TO ME!? - by jerryhawthorne - 10-22-2014, 01:00 AM
RE: WHY IS THIS HAPPENING TO ME!? - by PhilcoJohn - 10-22-2014, 09:15 AM
RE: WHY IS THIS HAPPENING TO ME!? - by Arran - 10-23-2014, 01:06 AM
RE: WHY IS THIS HAPPENING TO ME!? - by klondike98 - 10-23-2014, 11:59 AM
RE: WHY IS THIS HAPPENING TO ME!? - by Kekoa - 10-26-2014, 11:35 AM
There are currently 7636 online users. [Complete List]
» 2 Member(s) | 7634 Guest(s)
