Philco 41-250 rewire, mystery connector, external speaker
Here are photos of the Philco Antenna Coupler, designed to enable use of an external antenna on many 1941 and 1942 Philco models.
[Image: http://i326.photobucket.com/albums/k420/...o/ant1.jpg]
As you would see it plugged into the back of your radio, you can see a screw terminal for an external antenna and a switch on top of the unit. There is also a tab with a hole, allowing the unit to be bolted to the chassis.
[Image: http://i326.photobucket.com/albums/k420/...o/ant2.jpg]
Back view of the unit, showing the three-pin connector which matches the three-pin jack on the back of the chassis.
[Image: http://i326.photobucket.com/albums/k420/...o/ant3.jpg]
Viewed from the top, you can see the two-position switch is labeled "LOCAL" and "DISTANCE."
[Image: http://i326.photobucket.com/albums/k420/...o/ant4.jpg]
Underside view of the coupler. You can see a paper capacitor, a mica capacitor, and an inductor. There is also a resistor in there (not visible).
Philco 89 indicator light.
There are currently 8939 online users. [Complete List]
» 1 Member(s) | 8938 Guest(s)
