Philco 610 transformer open
1345-213 OUTPUT UNK 22E4 SP, 100:1 RATIO, 5-6 WATTS, FIG 3, TOP SEC LUGS, PRI 3"L,U 1 2 3/8 2 0/0 1 1/4 2.25
This is Fig. 3
http://oldradioparts.com/2a23g2.jpg
http://oldradioparts.com/2a23dfl.txt
Unfortunately there is a minimum order of $20.
Philco 610 transformer open - by Kestas - 10-22-2014, 10:11 AM
RE: Philco 610 transformer open - by morzh - 10-22-2014, 10:24 AM
RE: Philco 610 transformer open - by morzh - 10-22-2014, 10:33 AM
RE: Philco 610 transformer open - by Kestas - 10-22-2014, 11:00 AM
RE: Philco 610 transformer open - by sam - 10-22-2014, 12:21 PM
RE: Philco 610 transformer open - by Eliot Ness - 10-22-2014, 02:20 PM
RE: Philco 610 transformer open - by morzh - 10-22-2014, 02:28 PM
RE: Philco 610 transformer open - by morzh - 10-22-2014, 02:39 PM
RE: Philco 610 transformer open - by Kestas - 10-22-2014, 04:36 PM
RE: Philco 610 transformer open - by Kestas - 10-22-2014, 10:09 PM
RE: Philco 610 transformer open - by morzh - 10-23-2014, 10:55 AM
There are currently 10470 online users. [Complete List]
» 2 Member(s) | 10468 Guest(s)
