Dial restoration on a 38-14T
Yeah, I was about to pick up my jaw from the floor when I heard Ron replicated a gold foil dial...........to replicate just one piece......
It is embossed gold paper with pretty intricate pattern.
I think if anyone wanted to do this he would probably have to create a die from a good quality metal to use it to stamp out foil .....
Dial restoration on a 38-14T - by varrojames - 10-22-2014, 01:59 PM
RE: Dial restoration on a 38-14T - by Eliot Ness - 10-22-2014, 03:18 PM
RE: Dial restoration on a 38-14T - by Ron Ramirez - 10-22-2014, 09:32 PM
RE: Dial restoration on a 38-14T - by Arran - 10-22-2014, 09:50 PM
RE: Dial restoration on a 38-14T - by morzh - 10-23-2014, 11:03 AM
RE: Dial restoration on a 38-14T - by Steve D - 10-24-2014, 08:56 AM
RE: Dial restoration on a 38-14T - by Ron Ramirez - 10-24-2014, 10:11 AM
RE: Dial restoration on a 38-14T - by morzh - 10-24-2014, 10:18 AM
There are currently 10425 online users. [Complete List]
» 2 Member(s) | 10423 Guest(s)
