39.116 radio
 I would not continue operating this thing until you replace the leads on the power transformer, or you might end up with fireworks followed by a smoke show.
39.116 radio - by murf - 10-24-2014, 10:10 PM
RE: 39.116 radio - by klondike98 - 10-24-2014, 11:22 PM
RE: 39.116 radio - by Arran - 10-25-2014, 02:36 AM
RE: 39.116 radio - by Ron Ramirez - 10-25-2014, 08:46 AM
RE: 39.116 radio - by murf - 10-25-2014, 10:24 AM
RE: 39.116 radio - by PhilcoJohn - 10-27-2014, 06:51 PM
There are currently 10239 online users. [Complete List]
» 3 Member(s) | 10236 Guest(s)
