Need Philco 60 1st IF transformer
You're right, a 39 chassis is not as useful...
And I looked at the service info for the 39. While the IF frequency is the same (460 kc), the mounting and trimmers are different; so you're right, you can't use the IF transformers from the 39 in your 60 chassis.
I did not get to look for any IFs for you tonight, but I will try to do so tomorrow.
Need Philco 60 1st IF transformer - by Guest - 11-10-2008, 02:34 AM
Re: Need Philco 60 1st IF transformer - by Guest - 11-10-2008, 11:32 AM
Re: Need Philco 60 1st IF transformer - by Ron Ramirez - 11-10-2008, 11:21 PM
There are currently 9456 online users. [Complete List]
» 1 Member(s) | 9455 Guest(s)
